Re: can not get above 1500 psi
Posted by georgeky on May 02, 2007 at 20:41:22 from (152.163.100.197):
In Reply to: can not get above 1500 psi posted by danny beach on May 02, 2007 at 18:01:55:
Old is right. The 666 and 686 only run about 1600 unless you replace the pressure valve then it can go to 2500. I am not sure if you can put the high pressure valve in the 560 or not. They run about a hundred dollars.
