Farmall Tractors Discussion Board
Re: H with leaking pto
Posted by Phil Auten on May 05, 1999 at 05:00:47:
In Reply to: H with leaking pto posted by ed on May 05, 1999 at 02:02:44:
Ed,
Shouldn't be too hard to replace. Remove the pto from the tractor and drive the seal out carefully from the rear. Then take the seal to a bearing supply shop (if there is one near you). They should be able to match the seal and this will probably be the cheapest place to get it. Auto parts stores like NAPA should also be able to get a replacement if they don't have one in stock.
Good luck,
Phil
Who has to do the same thing to his M soon :o)
Post a Followup
: Re: Re: H with leaking pto
