Re: SUper H brakes.
Posted by jimmyjoe in mn on May 03, 2007 at 18:28:04 from (67.51.48.108):
In Reply to: SUper H brakes. posted by GordoSD on May 03, 2007 at 08:09:45:
Clean the rust off of the inside of the drums and with the actuators in the drum try to turn them and you will see where the tab on the actuator hits the stop in the drum. That is your power brake. If it does not turn easy you might have to grind a little metal off. That is what I had to do. Jim
