Re: can not get above 1500 psi
Posted by hockemfaster on May 03, 2007 at 18:35:42 from (205.188.116.138):
In Reply to: can not get above 1500 psi posted by danny beach on May 02, 2007 at 18:01:55:
Does anyone know what the pump will put out max? I am thinking about going to the 2500 PSI relief valve in my 706 also. I can't see where it would hurt the pump? It should run the pump to max and just relieve anything above 2500 psi in my mind. Then again I am not an expert. Anyone out there know what the pump will do max???
