Farmall Tractors Discussion Board
Re: H with leaking pto
Posted by The Red with further info. on May 05, 1999 at 07:46:50:
In Reply to: H with leaking pto posted by ed on May 05, 1999 at 02:02:44:
All the comments below are excellent. Bermuda Ken Updike has the parts. It is reference 4 for the oil seal and reference 5 for the retainer gasket. I recommend you purchase 2 seals. There is enough room for 2. Also have a clean can underneath the PTO when you take off the retainer. You will lose some 90W in the process that you can stick back in when you are done.
Also look at the base of the PTO assembly where it mounts onto the transmission frame and make sure you are not leaking there. I failed to do that while I had the system drained. So now I will have to drain out a couple of gallons and then remove the PTO to replace that seal. That ref. number is 19.
Ken's number is 608-455-2411. Parts will run you around $15 or so including shipping.
Post a Followup
: Re: Re: H with leaking pto
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
