Re: Jumps out of 5th Gear
Posted by H fanatic on May 03, 2007 at 19:17:23 from (71.115.85.59):
In Reply to: Jumps out of 5th Gear posted by Dave S. on May 03, 2007 at 19:06:42:
The same thing started to happen to my 46 Farmall H. What had happened was that the previous owner shifted on the fly and ground down the 4th and 5th slider gear. So what I am doing now is replacing it with a good used one. The reason it jumps out so easily is the it only meshes with the input gear about 1/8 to about 3/16 of an inch so it doesn't take much to make it pop out.
Hope this helps,
Nick
