Re: Jumps out of 5th Gear
Posted by Haas on May 04, 2007 at 12:47:20 from (12.65.18.32):
In Reply to: Jumps out of 5th Gear posted by Dave S. on May 03, 2007 at 19:06:42:
As others said, likely your 4/5th sliding gear is worn out. That is the one that has splines on the inside to mate with the small gear on the tranny input gear. These are frequently worn due to grinding gears to shift from 4th to 5th. I'd suggest getting a new one. Good used ones are not so easy to come by, as many have the same problem. Pretty big job to fix, as the main drive shaft has to be disconnected and the bearing cage and transmission input shaft have to be removed from the front of the transmission. Also easier if the transmission top is removed, although some say this can be done by just removing the belt pulley assembly. The problem could also be caused by a bad pilot bearing in the transmission. While you have the thing apart, probably best to replace that anyway.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
