Re: Super C questions
Posted by gene bender on May 05, 2007 at 03:46:45 from (67.55.226.214):
In Reply to: Super C questions posted by TR from SD on May 04, 2007 at 10:25:19:
the sw on lite controls red or clear. You mite need to replace the seal on the steering sector but fill with 90wt first you will soon fing out whether you need the seal. Not that hard to replace two gaskets and two seals one on the pedestal other on the input shaft. If you remove the pedestal be sure to replace it tilted back position as they steer better that is why I-H tilted them back couple degs.
