Farmall Tractors Discussion Board
Re: 6 to 12 volt conversion SUPER A
Posted by JOHN on May 05, 1999 at 13:47:27:
In Reply to: 6 to 12 volt conversion SUPER A posted by mike on May 05, 1999 at 11:11:19:
I DON'T KNOW ABOUT A CONVERSION TO 12 VOLT BUT I HAD ONE WITH A 9 VOLT BATTERY MADE BY INTERSTATE. NO CONVERSION WAS REQUIRED BUT I UNDERSTAND FROM THE PREVIOUS OWNER THAT THE VOLTAGE REGULATOR HAD TO BE ADJUSTED TO PUT OUT OVER 9 VOLTS TO CHARGE THE BATTERY. I RAPLACED THE BATTERY LAST YEAR AND THE LOCAL INTERSTATE BATTERY DEALER HAD ONE IN STOCK. THE STARTER HELD UP FINE TO THE 9 VOLTS AND TURNED OVER WELL IN COLD WEATHER. I NOW HAVE A FORD WHICH HAS BEEN CONVERTED TO 12 VOLTS. THE GENERATOR AND VOLTAGE REGULATOR WERE REMOVED AND REPLACED WITH A 12 VOLT ALTERNATOR. THE 6 VOLT STARTER IS HOLDING UP FOR NOW.
Post a Followup
: Re: Re: 6 to 12 volt conversion SUPER A
