Re: r.rear axle locked Farmall H
Posted by georgeky on May 05, 2007 at 12:31:40 from (152.163.100.197):
In Reply to: Re: r.rear axle locked Farmall H posted by Dhpr on May 05, 2007 at 12:24:33:
If the axle wasn't locked up when you parked it. I would guess it is the brake. Try taking the brake drum off and see if the wheel turns then. If it has been moved and quit turning while moving there might be something caught between the bull and pinion gears. This will likely require the top deck to come off.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
