Re: 1466 dash lights
Posted by Allan In NE on May 06, 2007 at 06:00:47 from (148.78.243.24):
In Reply to: 1466 dash lights posted by brian t from ohio on May 05, 2007 at 19:54:18:
Brian,
You're probably gonna find that every bulb in 'er is burned out or the metal socket has a bad ground.
That circuit runs from the light switch, out to the junction block under the right side rear cowl panel and then from there on out to each individual light socket.
Trace 'er with your test light.
Allan
