Re: Temp control lever for All-fuel?
Posted by RustyFarmall on May 06, 2007 at 12:31:35 from (66.43.253.62):
In Reply to: Temp control lever for All-fuel? posted by Mike CA on May 06, 2007 at 11:24:53:
I did have a picture of one, but I have deleted it from my files. Basically it is an "L" shaped steel rod, with one end inserted into a hole in the manifold. The "L" will have a set screw in the end that is visible. There will also be indicators on the manifold which will show you where to set the lever. If the lever is missing, there will be a hole in the manifold where the lever should be. If there is no hole, then it is not a distillate manifold.
