Re: Temp control lever for All-fuel?
Posted by Steven@AZ on May 06, 2007 at 13:17:49 from (24.121.155.253):
In Reply to: Temp control lever for All-fuel? posted by Mike CA on May 06, 2007 at 11:24:53:
third party image
third party image
1 and 2 point to the bolts that are used to hold the "chimney" on the manifold for the exhaust. There is not a threaded hole on the all-fuel type manifold.
3 points to the temperature adjustment. You can set it for cold, medium, or hot. You could adjust it for the best power/most complete burn of whatever fuel you were using - might need more heat in the winter as apposed to summer time.
