Re: Farmall differential question......
Posted by Janicholson on May 07, 2007 at 07:08:15 from (199.17.6.122):
In Reply to: Farmall differential question...... posted by Patrick Martin on May 06, 2007 at 18:39:28:
I enter the frey. With a mental description (fun I hope) Imagine the capital letter T. Put a pivot point at the place where the top intersects the vertical part, so the top coule move like a teeter-totter. lay it down flat (in your mind) on a table. Now if you pulled the T along with the vertical part as the handle the top would also be pulled along. if we put a small fishing wt on each side of the top, all the way out to the end, there would be equal drag on each side, and the top would remain perpendicular to the "tongue" because the amount of drag on each side is equal. Now if the T was pulled through a bit of a waxed spon on the table with only one side of the top of the T passing through it, the top would pivot and the easy to slide end would go fast, and the other side would stop. That is what happens inside the differential. Though the T is composed of a set of spider gears abd side gears, it is effectively identical. If the rear end of most tractors and cars is lifted off the ground, one tire can be turned forward, and the other will turn the opposite rearward (unless they have a differential lock, or "positraction" or some other system). Equal amounts of force are applied to both. When one of the brakes is applied, the brake force just drags the slipping side back so that the opposite tire gets more force. JimN
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
