First Aid
Posted by A. Bohemian on May 07, 2007 at 13:34:22 from (207.170.88.57):
In Reply to: farmall M looses power after running for awhile posted by Linda Raynes on May 07, 2007 at 13:04:15:
I'm sorry to hear about your husband, Linda. Problems with loss of power after warm-up often come from one of two areas: (a) insufficient fuel flow (fuel flow has time to catch up when tractor shut off, so runs well from start), and (b) expansion due to heat causing an electrical component to fail. I like to start with fuel flow first, because it's easiest to check. Turn on the gas at the cut-off and pull the drain plug on the bottom of the carburetor, if your M has one. You should have a good, steady flow about the diameter of the fuel line. A trickle may not be good enough. In this case, since the problem is intermittent, you may want to run a full tank though, to give the problem a chance to occur. Make sure and catch the gasoline in a sutiable container for re-use (USD 2.79 locally!). If there is water in the system, it usually comes out first. Obviously, in that case, the gasoline itself is suspect. Fuel flow not ok? Check sediment bowl and tank for crud and rust (you'll want a gasket handy for replacing the bowl). It may be necessary to remove and clean any screens in the tank or carb. More detailed instructions can be provided in the event this is necessary. Fuel flow ok? Check back in with us. Good luck and keep us posted. Model M can be very troublefree and I believe there may be several thousand of them still running.
Home
| Forums
Today's Featured Article -
Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
