Re: Super A Steering
Posted by Hugh MacKay on May 07, 2007 at 17:45:45 from (216.208.58.163):
In Reply to: Super A Steering posted by Smitholm on May 06, 2007 at 17:57:18:
Smitholm: If there is no end play in the steering shaft, I wouldn't even take it out. 90% of these the trouble is right in the vertical shaft within the steering box. I have seen that one alone give a full 360 degree turn on the steering wheel. Two places on that shaft become loose; where the 1/2 gear is keyed to shaft and steering control arm.
All you need do is block tractor well under clutch housing, disassemble the front axle and remove bottom of steering box. I've fixed or helped fix about 15 of these. Only one did we have to touch the shaft, bearing and worm. Almost without exception, problem was in the vertical shaft. I have never seen a set of gears worn enough to seriously affect steering.
