Re: 1937 Farmall F-20 Throttle Problems
Posted by Bob Kerr on May 08, 2007 at 04:11:29 from (64.12.117.8):
In Reply to: 1937 Farmall F-20 Throttle Problems posted by Mpuller44 on May 06, 2007 at 16:57:44:
I am not sure if the f-20 has the same gov as the 10-20 does, but I suspect they do. My 10-20 acted up bad when I first got it running and the problem was the Die cast or pot metal "tube" has a spring inside and it was a bit too loose. I just turned the tube a few turns and the spring inside snugged up and it worked perfect after that, and it did govern at low speeds. the Tube is just to the rear of the oil fill cap and lays horizontal. It is about 3 inches long or so.
