Re: New Farmall 560 and fast hitch plow question-
Posted by the Unforgiven on May 08, 2007 at 08:16:12 from (66.146.249.116):
In Reply to: New Farmall 560 and fast hitch plow question- posted by Ron PV on May 08, 2007 at 06:24:44:
There is a hole in the front of the FH socket, you put a pin in it to lock the socket in place, that should take care of the plow riding up when you lower it. As far as the tailwheel dragging I'm really not sure, those sockets should only pivot one way, should lift fine and pivot to almost give a no-down pressure condition when lowered. The pin for the real down pressure control is below the bottom end of the cylinder.
