Re: No power under load
Posted by georgeky on May 08, 2007 at 09:31:57 from (64.12.117.8):
In Reply to: No power under load posted by Indiana GeorgeN on May 07, 2007 at 18:02:44:
It should pull the disk in 2nd and 3rd depending on what size the disk is. The water pump will not have anything to do with it. As Jim said it could be lack of fuel. There is a screen at the carb where the fuel line attaches try cleaning it to see if it helps. If it has a in line fuel filter take it off and try it without it. Clean the entire fuel line and sediment bowl. There could also be junk in the tank restricting fuel flow. It could also be the governor. Does it miss or just no power? You need a IT service manual it will give proper governor adjustments, and a wealth of other info. Is this something that just started or has it been this way since you had it? Without being there it is hard to tell what it may need.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
