Re: New Farmall 560 and fast hitch plow question-
Posted by Nat 2 on May 08, 2007 at 12:16:35 from (64.80.108.52):
In Reply to: Re: New Farmall 560 and fast hitch plow question- posted by Ron PV on May 08, 2007 at 08:30:16:
Just because it has fast hitch prongs does not make it a fast hitch plow.
The prongs could be 3 point-to-fast hitch adapters that slip over the 3 point pins on the plow.
Disconnect the tractor from the plow. Now look at the prongs.
Are they held on to the plow by a single large bolt or pin? If you can pull the prongs off the plow by removing one large bolt, or a quick clip, then you do NOT have a fast hitch plow. It is a 3pt hitch plow, and you will need a top link to make it work correctly.
