I want to thank everyone for your replies
Posted by Linda Raynes on May 08, 2007 at 13:22:27 from (71.241.46.72):
In Reply to: farmall M looses power after running for awhile posted by Linda Raynes on May 07, 2007 at 13:04:15:
Thank you for your replies. I will try your suggestions this weekend and get back to each and every one of you. I am overwhelmed by your generosity and kindness
Linda
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
