Farmall Tractors Discussion Board
Re: H governor spring
Posted by The Red. No longer made on May 06, 1999 at 08:03:25:
In Reply to: H governor spring posted by John on May 06, 1999 at 07:53:21:
The 2 hook is the only one made that I am aware of. If it was made, Ken Updike would be selling them. You just need to give it a twist to install it. Check your thruster and bearing while you have the spring out. Should be no wiggling of the bearing on that shaft.
Post a Followup
: Re: Re: H governor spring
