Re: Stuck piston woes
Posted by Janicholson on May 09, 2007 at 06:31:09 from (199.17.6.122):
In Reply to: Stuck piston woes posted by sccwells on May 09, 2007 at 06:08:48:
Use a muffler chisel (dog legged hand tool with a curl cutting shape to the business end) and start in the hole you have and work to the side (not toward a pin boss, but the side of the engine) and cut away the pieces a bit at a time. Form a slot that heads for the piston rings from the inside out. Do not wedge or cut toward the outside first it will crack the cylinder wall casting. The rings are cast iron and will break easily. Leave serious pressure on it from the bottom, just shy of lifting the tractor. JimN
