Re: Stuck piston woes
Posted by CHIEFEAVES on May 10, 2007 at 07:18:48 from (152.163.100.197):
In Reply to: Stuck piston woes posted by sccwells on May 09, 2007 at 06:08:48:
I EXPERIENCED THE SAME PROBLEM WITH MY 39 "M". I TRIED ALL TYPES OF CHEMICALS WITH NO RESULTS. I REMOVED THE HEAD, OIL PAN AND BOTTOM HALF OF PISTON BEARING. THEN I PLACED A PIECE OF 2/4 WOOD AGAINST THE ROD AND TAPPED THE WOOD. IT PUSHED THE PISTON AND SLEEVE OUT THE TOP. THE TRACTOR HAD BEEN SITTING IN THE PASTURE FOR 20 ODD YEARS WITHOUT A COVER OVER THE EXHAUST. NO 3 WAS THE ONLY PISTON THAT WAS STUCK. GOOD LUCK
