Re: 706 tans oil
Posted by the tractor vet on May 10, 2007 at 14:57:28 from (75.19.120.63):
In Reply to: 706 tans oil posted by Greg Lasher on May 10, 2007 at 08:45:31:
It is a common sump trans mission rearend and hyd. all the same and ya use HY TRAN . Filter on lower right side of rear frame under teardrop cover . When cover is removed you will loose about one gallon of oil . As far as checking anything else , yes the final drives as they do not get oil from the rear end Unless at one time someone had the back end apart and updated it by drilling a hole in the bottom of the rear end on each side . So on the flang part of each rear axel housing you will find a plug half way up for the fill and level of the oil and on the vary bottom of each is a drain plug takes a 3/8ths square plug socket Ya can get by sometimes with a 3/8ths extenchion But due to the slight roundness of the edges on a extenchion many have been rounded out as it does not fit like a plug socket does.
