Re: 656 intenational injector pump manual[stanadyn
Posted by the tractor vet on May 10, 2007 at 17:25:09 from (75.19.120.63):
In Reply to: 656 intenational injector pump manual[stanadyne] posted by Randal Rutherford on May 10, 2007 at 16:46:22:
If ya are not experance in injection pump work then it is wise to keep your pinkies out as a twist here and a twist there can cause some of the inside pices of the engine to be on the outside in short order . As for the adjuesment on the outside of the pump ya have high and low idel and the load screw and that one best leave alone along with the high idel . And you can not tell what the pressure is just by cracking a line or two . If the engine has a miss it could be a bad injector and here again with out the proper test equipment ya ain't going to DIY it . Even with the book ya still have to have one of them test stands to set and check .
