Re: Where should I start?
Posted by old on May 10, 2007 at 17:29:44 from (4.245.2.116):
In Reply to: Where should I start? posted by Mike CA on May 10, 2007 at 17:20:44:
Some times to turn the engine with the fan you have to use one hand on the fan and the other one on the belt to push it tight. You can also set a battery in it and hit the starter button to see if it turns over. And yes the first place to start is to get it running then go from there. Takes 6 qts of oil. To start with I would use a 30W oil say from wal-mart just to get it up and running then change it after an hour or 2 of running, that way you clean out the rust and sludge that might be in it. I would also put about a 1/2 cup of tranny fluid in each cylinder just to prelube the top of the engine and to free up any stuck ring etc.
