Re: radiators
Posted by Hugh MacKay on May 10, 2007 at 18:35:19 from (209.226.106.16):
In Reply to: radiators posted by banjo on May 10, 2007 at 16:37:11:
banjo: I will respond as I haven't seen tractorsam around in awhile. He installed one of these rads the were for use with water pump. In the end he had to add a pump. This is about the 4th time I've heard this, just wondering if the thermosyphon type radiator is no longer available. Could be, pump is the only way to go.
