Re: 806 - no start
Posted by Brownie450 on May 10, 2007 at 19:53:09 from (207.177.82.220):
In Reply to: 806 - no start posted by IN on May 10, 2007 at 17:48:06:
Does it turn over when you jump the solenoid terminals? If it does, your problem is from the ign. switch--starter switch---clutch safety switch--- possible solenoid small wire connection. Our 1066 had this sort of goings on, & it turned out that the heavy battery cable was eaten out where it attached to the big terminal on the solenoid. Cleaning the cable end, & putting a "star" washer plus the lock washer on the stud solved the problem. Hope yours is that easy.
