Farmall Tractors Discussion Board
Re: advice on rebuilding motor on my farmall cub
Posted by TMAC on May 06, 1999 at 17:12:07:
In Reply to: advice on rebuilding motor on my farmall cub posted by Dan on May 05, 1999 at 19:29:20:
I agree with Walter. I'm guessing you have the head off since you know it is rusted. Check the valves also they may be rusted too. If you think that only that piston is stuck, disconnect the rod and see if the engine will turn. If so soak it with penetrant. You can tap it from the top and try to move it down(move the crank out of the way). If it moves down, tap it back up and repeat.
Post a Followup
: Re: Re: advice on rebuilding motor on my farmall cub
