farmall H generator belt
Posted by redforever on May 11, 2007 at 19:59:29 from (69.221.240.238):
Looks pretty complicated putting a generator belt on this tractor. Would a Power Twist link V belt work? Does anyone have the specs on the oringal belt that was used "length and width"? If I have to use the original style rubber belt, do I need to remove the radiator, fan, and fan belt or will the generator belt fit over the fan once the fan belt is removed? One more question, was the the adjustable pulley on the H on the tractor or on the generator? PLEASE HELP, I really want to get electric on this tractor.
