Re: Head Gasket Replacement on Super A
Posted by Jim Becker on May 11, 2007 at 20:34:11 from (71.164.236.107):
In Reply to: Head Gasket Replacement on Super A posted by Hartford in Beeton on May 10, 2007 at 17:53:57:
Even ignoring the the Rx update type variations, I have seen 5 different part numbers for the various C-113, C-123 and early C-135 engines. The differences I am aware of are the water passage size (smaller for water pump) and the size of the opening at each cylinder. The original C-113 gasket would overlap the edge of each cylinder if it was a larger bore, so a change was required for 3 1/8" bore engines. At one time, different gaskets were available for different bore engines. The only currently available numbers I could find are 366300R3 and 366301R2. Since 366300R3 is correct for a C-135, it is OK for a 3 1/4" bore with a water pump. 366301R2 is for engines with no water pump and I am guessing it is OK for a 3 1/4" bore as well.
The key to all this is the Farmall C Parts Catalog. It is the only model that had an optional water pump and it lists these 2 gaskets based on water pump or not.
If you have already installed 366300R3 and were using the same before, I would probably not go back and change it. It might become a problem if you run the tractor hard.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
