Re: SuperC carburetor
Posted by Brownie450 on May 13, 2007 at 03:59:15 from (207.177.82.77):
In Reply to: SuperC carburetor posted by Mark Johnson on May 12, 2007 at 16:38:31:
If your carb bowl is warped or not level, flat it by holding a piece of emery cloth on a 2x6, & run the bowl on the abrasive by hand. Run 2 or 3 strokes, then check for flat. Continue until surface of bowl is level. AS far as the float level goes, you may have to go 2 or 3 times to get it right. It took 3 times on our carb to get it to stop blowing black smoke. This was from the setting that was given on the spec sheet. You'll do OK on the carb, just take your time & don't rush it.
