Re: 460 utility
Posted by PaulW_NJ on May 13, 2007 at 04:17:21 from (70.111.87.67):
In Reply to: 460 utility posted by TGIN on May 13, 2007 at 03:46:47:
third party image
I believe the setup onthe 460 is similar to that on my 340U. You apparently are missing a spring (#12) that connects the crescent to a fixed bracket bolted as I recall onto the hydraulic valves manifold. There is a friction disc (#3)under the throttle handle that counteracts the spring and sometimes has to be replaced.
