Re: Which Head Gasket for SuperA with 3 1/4 Piston
Posted by georgeky on May 13, 2007 at 07:09:13 from (205.188.116.138):
In Reply to: Re: Which Head Gasket for SuperA with 3 1/4 Piston posted by Hugh MacKay on May 13, 2007 at 03:38:43:
Hugh, I don't pull it , but I do work the snot out of my 1949 C with 123 pistons and no water pump. However it does have to have water added every couple of days during hot weather as it will slowly boil it away. It was this way when I bought it in 1975 and I didn't even know it until 1998 when I had to replace the crankshaft due to me breaking it with a sledge trying to drive that puuley on. Anyhow it does work and run fine.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
