Re: reducing tread marks. 300U
Posted by old on May 13, 2007 at 09:15:19 from (4.244.57.189):
In Reply to: reducing tread marks. 300U posted by JayWalt on May 13, 2007 at 07:10:56:
Yep wider tires or duals work well. With the loader you almost have to have that fluid or you will be spinning the rear tires a lot and that will really dig up the ground. Also wider front tires or a set of truck tires up front will help a lot. On my loader tractor I run 7.50X16 truck tires up front to keep the front wheels from digging in as bad, when I had the normal rib type fronts I would dig in a lot and cause problems getting stuck
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
