Farmall Tractors Discussion Board
Re: Re: Re: Re: advice on rebuilding motor on my farmall cub
Posted by George on May 06, 1999 at 20:24:51:
In Reply to: Re: Re: Re: advice on rebuilding motor on my farmall cub posted by dan on May 06, 1999 at 20:02:43:
There is a good vidio showing a complete engine rebuild for a Cub available from Country Tractor and probably a number of other sources. It's title is "Engine Rebuilding for Cub & Lo-Boy Tractors" produced by J&D Productions, Inc. P.O. Box 38, Metamora, MI 48455. The parts you need should be available if all that is wrong is a rusted cyliner. But what you describe may have another cause. You may need to check for a cracked block or head to see if coolant leaked into the cylinder since its hard to imagine that enough moisture could have gotten into the engine to cause the damage you describe in just a couple of months of outside storage.
Post a Followup
: Re: Re: Re: Re: Re: advice on rebuilding motor on my farmall cub
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
