Re: SuperC carburetor
Posted by georgeky on May 13, 2007 at 20:42:48 from (64.12.117.8):
In Reply to: Re: SuperC carburetor posted by Mark Johnson on May 13, 2007 at 19:33:07:
Yes a good kit will have instructions with it.As for which carb, you have no way of knowing until you get it off. These are old and anything can happen. I took one off a 52 Super C the other day that is L48J. It didn't even fit someone had used smaller bolts because the holes were off by 1/8 of an inch. They used bolts with nuts on them. More than likely yours is 67X7, but I would make sure before buying the kit.
