Re: Crank Start
Posted by georgeky on May 14, 2007 at 05:24:08 from (152.163.100.197):
In Reply to: Crank Start posted by oldgit on May 13, 2007 at 23:08:17:
Make sure the timing is good and the carb is clean and adjusted properly and the thing should hit right off. You should start with the crank at the bottom and pull up. It is a risk to try spinning it 360 degrees. If your tractor tends to flood it will not be easy to crank and start.
