Re: Crank Start
Posted by agpilot on May 14, 2007 at 06:11:14 from (206.146.78.170):
In Reply to: Crank Start posted by oldgit on May 13, 2007 at 23:08:17:
Hello oldgit
You had it fire on just one cylinder and you have a nice blue spark? Are both of those items on the very same cylinder? Check spark on the other three. If you have spark on all, then your missing fuel. More choke. I prefer throttle set to about 900 rpm area. I use full choke for 2 pulls and then set choke to slightly less then full choke so that on the 3ed pull it starts but does not choke itself off. agpilot
