Re: Batttery Cable Hookup
Posted by Bob M on May 14, 2007 at 07:20:41 from (151.190.254.108):
In Reply to: Re: Batttery Cable Hookup posted by Janicholson on May 14, 2007 at 06:34:23:
Jim - On a 12 volt-converted tractor, smaller diameter cables (eg. AWG #2) work fine.
In fact smaller cables may actually help extend starter life by somewhat limiting starter "inrush" current. This in turn reduces shock on the starter and drive when you first hit the starter switch.
But even the smaller cables still let the starter spin the engine way faster than the stock 6 volt system ever could.
Josh - Like Jim says: Unless you have a real oddball alternator arranged (and marked) for positive ground, the negative battery cable is the one that must be grounded.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
