Re: Blowed Cub engine
Posted by El Toro on May 15, 2007 at 04:08:38 from (152.163.100.197):
In Reply to: Blowed Cub engine posted by Farmallb on May 14, 2007 at 20:01:27:
You need to do some investigating before ordering any parts. Pull the head and drain the oil and look for metal particles in the oil. I would pull the oil pan and check the rod and main bearings to see if you have spun a bearing. If there's a spun bearing you will need to split the tractor. Then do a complete engine teardown. Hal
