Re: Farmall H with bad oil
Posted by Michael Soldan on May 15, 2007 at 10:03:00 from (24.235.41.226):
In Reply to: Farmall H with bad oil posted by Andrew A. on May 15, 2007 at 09:51:43:
That, Andrew is water in the oil breather..wash the entire breather and cup in varsol, wipe all the goop out of the bottom of the cup. Let it drip dry or blast it dry with the air gun. Fill the breather cup with the same oil you use in the engine...30, 30 HD. 10w30..whatever...There is a mark on the oil bath cup to show you where to fill it to. You might want to check the colour of your rear end oil if it is that bad in the oil bath..tractor may have seen to much wet weather outside...
