Re: Farmall 756 with German 310 ( few Questions)
Posted by georgeky on May 15, 2007 at 10:13:12 from (205.188.116.138):
In Reply to: Re: Farmall 756 with German 310 ( few Questions) posted by chadd on May 15, 2007 at 07:31:13:
I plug mine in at 35 or less, so it don't take so long to warm it up. I use to have 656 with glow plugs, if they didn't work, you couldn't start it with dynomite. It was a real tractor, just hard to start.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
