Re: Cub wont start!!!!!!!!!!!!!
Posted by El Toro on May 15, 2007 at 14:52:05 from (64.12.117.8):
In Reply to: Cub wont start!!!!!!!!!!!!! posted by 1941 farmall a boy on May 15, 2007 at 13:53:50:
Are you getting fire to the sparkplugs? You probably need to clean the points. Take some 320 wet or dry and clean the points until nice and shiny. Pull one of the sparkplugs to see if it's wet with gas. If its dry, squirt some gas into the plug hole. Reinstall the plug and see if the engine will run. Hal
