Re: Cub wont start!!!!!!!!!!!!!
Posted by old on May 15, 2007 at 18:02:32 from (4.244.90.168):
In Reply to: Re: Cub wont start!!!!!!!!!!!!! posted by 1941 farmall a boy on May 15, 2007 at 17:04:03:
Before you do much with it I would pour some tranny fluid in the cylinders. That will help up the compression and also loosen up the rings and prelube the cylinders. I know you said it has been sitting a while and that will help it a lot. I would also do a full tune up on it, points, plugs, condenrser and cap and rotor if it has a distubutor instead of a mag
