Tom Windsor
Posted by Dave S. on May 15, 2007 at 19:33:24 from (208.13.218.122):
Tom the seal # for your brake shaft is a CR-541901 if you need it. They are a much thiner seal than the original, you can put in 2 one behind the other if you want.
