Oil/water/condensation
Posted by Tedd on May 16, 2007 at 05:42:11 from (144.71.145.22):
Andrew asked a question about bad oil in H which makes me wonder. Each year we go through the normal maintenance; oil change filter change/clean and grease. It is scary to see how much moisture/water that can accumulate from condensation. A tractor that sits all winter in the northeast could have a cup of clear water in the pan which runs out before the oil when you remove the plug. This spring my brother removed the valve cover on an M and the inside of it was coated with a thick slimy layer of white-tan moisture and oil combination. After scrapeing and cleaning the volume could easily fill a 16 ounce beverage container. I'm glad we did not run it warm and dissolve it into the oil. It makes me wonder when some people have said they did not run it much last year and the oil still "looks" line new.
