Re: Farmall Super A buying questions with Hyd Prob
Posted by Ron-MO on May 16, 2007 at 07:42:23 from (208.210.74.251):
In Reply to: Farmall Super A buying questions with Hyd Problems posted by Chad from Michigan on May 16, 2007 at 06:38:50:
Should be the same hydraulics as is on my C. The fill is on the left side while sitting in the seat. Square plug on the side of the hydraulic unit below the gas tank. Fill just below the plug. As someone else stated if the oil is fine check the screen. Should be 4 bolts just to the side and below the plug if memory serves correctly. Does not sound like a pump to me and these are pretty durable. My C has been working for well over 50 years with no rebuild on the pump or hydraulic unit. I did have to replace the o-ring in the pump as it was leaking into the crankcase, and a couple o-rings on the control rods, but it still works very well, and I dont think these are that difficult or expensive to rebuild, although the pump might get expensive if you had to buy one.
