Re: M Steering Wobbly
Posted by John S-B on May 16, 2007 at 14:29:28 from (69.218.225.105):
In Reply to: M Steering Wobbly posted by Lance_MF_180 on May 16, 2007 at 10:22:53:
Lance, I just put in new bushings into my M. It did wonders, absolutely no wobble in the front end. I did have the 360 degree sector gear, but I could tell it had already been rotated 180 degrees but did not have excessive wear but I still rotated it 90 degrees to be centered on the two sides that had wear already. The parts cost about $130 for the complete set but it did not include the seal for the steering wheel shaft. The job can be done by one person but two is easier. I used a pair of vice grips with the chain for pipe to hold the upper bolster in place. I have a couple of pics in the stuck and troubled gallery if that might help. Just do a search for my name and that should bring it up. I still have a little play in the steering wheel but that is from the u-joint that I will get to when I replace the steering wheel.
